Intel® Desktop Boards
Peer-to-peer support only
11432 Discussions
DH87mc Raid 1 ... First Time
AT11
I got my self DH87mc with 1 Intel SSD , 2 1TB WD & 2 2TB WD.. I am currently running Win 7 on the ssd and the windows Raid 1 on the 1tb and 2tb Hdd.
I do see Raid 1 is supported on the DH87mc . But I remain with Two questions..
1. The 1tb and 2 tb hdd i am using are discs which contain data.If I configure PCH Raid 1 will I loose te data already on it.
2. Will a power failiure or any other act..?? Cause the raid to re-initialise??
Jose_H_Intel1
You can keep the data from one of the drives when creating a RAID 1 with Intel® Rapid Storage Technology software. Please check pages 30-33 of the user guide.
If one of the disks fails, the RAID array becomes degraded, and rebuilding is necessary to maintain the RAID array healthy once the failed member drive is replaced. See page 9.
http://www.intel.com/support/chipsets/imsm/sb/CS-020670.htm Intel® Rapid Storage Technology (Intel® RST) — User Guides
j_tree
boot ctrl-I
RST>
Create Volume Menu
RAID Level: RAID1 (Mirror)
(Disks - Strip Size N/A)
Capacity: 931.5 GB
Sync: N/A
Create Volume
Help: The default value indicates the maximum capacity using the selected disks. Entering a lower capacity allows you to create a second volume on these disks.
WARNING: ALL DATA ON SELECTED DISKS WILL BE LOST.
Are you sure you want to create this volume?
>>escape / No! /
