Intel® Desktop Boards
Peer-to-peer support only
11476 Discussions
DIMM Slot poblems with Intel DH67CF.
KEkho1
I have problems with one of the DIMM slot, if I have both DIMM slot installed with memory, the computer doesn't start at all,
otherwise it works fine. This problem occur when I installed a new processor.
Is there a tool that can check if it exist any hardware failures?
The mainboard model is Intel DH67CF and processor model is Intel Core i5-3470T 2,9 Ghz.
I have also includes MEDIA-PC.txt file which contains info about mý hardwares created by CPU-Z version 1.65.1.
Can someone help me with this issue?
Kevin_M_Intel
Hi ekke76,
I am sorry to hear you are having problems but let me help you.
Based on the information you provided, have you tried installing the latest BIOS update for your system? Have you tried different memory?
