Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DK77MK + i7-3770T + HyperV Server
have tried to run Windows 2008 Server with Hyper-V on the DK77MK board with a i7-3770T CPU.
Installation and configuration was easy and works fine but if I try to start a VM windows shows a error message.
"Hypervisor is not running"
Virtualization is activated in BIOS and XEN Server is running without problems.
Does this board or the CPU does not support the MS Hyper-V Server ?
Community Manager
Hello Mr. T,
I understand that you wish to know if your motherboard and processor support Microsoft* Hyper-V Server 2012*.
In regards to your inquire, the hardware is not designed to run the software, by this I mean that Intel(R) does not validate the compatibility with third party software. I can confirm that they will support VT-D and VT-X that is required.
I do recommend you to check with the developer for other possible causes including compatibility with the motherboard.
Regards.
PV
