Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
DMA controller IRQ
jh_08
I'm trying to do a DMA with DMA controller, the DMA works but I'm not able to generate the automatic IRQ (when length register is 0).
In the QSYS, i've connected the IRQ sender of the DMA controller block with an IRQ receiver in a custom VHDL block. To check if the IRQ is generated, I put this signal directly to an output pin to monitorize it with an oscilloscope.
Can anybody tell me why this IRQ is not generated?
In Nios code, I put diectly the values to the registers, I'm not using HAL.
Code:
IOWR_ALTERA_AVALON_DMA_CONTROL(DMA_BASE, 0x0194);
IOWR_ALTERA_AVALON_DMA_RADDRESS(DMA_BASE,DMA_READ_MASTER_MCU_INTERFACE_BASE);
IOWR_ALTERA_AVALON_DMA_WADDRESS(DMA_BASE,
DMA_WRITE_MASTER_SDRAM_BASE);
IOWR_ALTERA_AVALON_DMA_LENGTH(DMA_BASE,128); //specifies length (in Bytes)
IOWR_ALTERA_AVALON_DMA_CONTROL(DMA_BASE, 0x019C);
while(IORD_ALTERA_AVALON_DMA_STATUS(DMA_BASE) == 0x02);
IOWR_ALTERA_AVALON_DMA_STATUS(DMA_BASE,0x10);
Thank you!
