Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
DN2800MT: Automated way to set BIOS?
RCiur
All,
Hello and good day...
Is there a way to install a BIOS image in a DN2800MT board and also load my chosen default parameters without needing to navigate the configuration screens?
Currenly, I'm using the Jumper/USB flash method to install the BIOS image. I also have a preferred set of default parameters. The folks at the manufacturing facility will not like the 5 minute long (error prone) method of manual BIOS configuration -especially since they will have a few thousand boards to configure.
Any suggestions, alternate methods of loading and configuring BIOS, etc -to accomplish this is greatly appreciated.
Ray
Silvia_L_Intel1
Hello RayC,
Yes, the BIOS image can be changed and all of the different BIOS options can be modified as well. You can do this by using the Intel(R) Integrator Toolkit.
You can download it on the following link Download Center.
The Read Me file will provide you the instructions on how to use it.
Sylvia L
Silvia_L_Intel1
Hello RayC,
Sylvia L
RCiur
Silvia_L_Intel1
Alexander_L_Intel
Intel(R) Integrator Toolkit works with desktop BIOSes only.
How would I do the same for Intel nootebook/ultrabook systems please? Why is it limited to desktop boards only?
Alexander
