Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
DN2800MT Non Boot with TBS6981 PCI-e Card
BNeav
My DN2800MT board is set up with mSATA OCZ NOCI 60gb + 1 off 4GB Kingston SoDIM, its running Windows 7 Ultimate with the latest BIOS from September flashed.
The PC runs fine and does all as expected until i plug my TBS6981 DVB S2 Tuner card in, once plugged in and powered on the board does nothing other than illuminate the power light, the VGA doesnt bring the monitor out of standby and i don't get any POST indication or beeps (not sure if there is an onboard beeper). All i can do is just power it off again.
I have tried almost every setting in the BIOS and i get the same effect
From what i can see the card is PCIe 1 compliant using a boot, n2800mt
PCIe bridge: http://linuxtv.org/wiki/index.php/Conexant Conexant CX23885 chip
http://www.tbsdtv.com/products/tbs6981-dvb-s2-dual-tuner-pcie-card.html TBS6981 DVB-S2 Dual Tuner PCIe Card-Internal TV Tuner Card for PC
http://linuxtv.org/wiki/index.php/TBS_6980/6981 TBS 6980/6981 - LinuxTVWiki
Latest drivers etc installed, although this doesnt sound like its a driver issue
Silvia_L_Intel1
Ben64, we try to make our products compatible to many third party components as possible, but we cannot always guarantee compatibility. Unfortunately in this instance this would appear to be the case.
Have you tried another PCI device on your motherboard, like a video card, in order to check if you got the same behavior?
BNeav
Hi
It does seem to be a common issue with some motherboards, but it does appear to be the motherboards issues rather than the card. it seems to suggest it will work as long as the PCI-e spec has been followed correctly
http://www.tbsdtv.com/forum/viewtopic.php?f=21&t=8463 TBSDTV Community Forum • View topic - About PCI-Express compatibility issues
