Intel® Desktop Boards
Peer-to-peer support only
11430 Discussions
DN2800MT USB Standby Power Bios 0164 and 0165 broken?
Community Manager
Hello
I have 2 Boards of this Type.
1 Board ships with Bios 0163 the USB Standby Power work.
2nd Board comes with 0164.
If I setup the option in bios it don`t work.
I flashed the latest 0165 USB Standby Power don`t work.
I cant`t downgrade the Bios of the 2nd Board it says "its not allowed".
Can i flash the 0163 via recovery?
Or there any hardware changes on newer Boards who can`t work with this Version?
I used it as a Car Music Servers.
The same Hardware in every PC.
It runs an OpenSuse 12.3 System.
RRamo7
New Contributor III
Hi Frankg63,
If the issue happens with 0164 and 0165 BIOS versions, you can go ahead and downgrade it to 0163, but using the BIOS recovery method as you mentioned.
Please download the ".BIO" file BIOS version 0163 from Download Center
Please find the Instructions for Recovery BIOS update here: http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm?wapkw=bios+recovery+method Desktop Boards — Instructions for Recovery BIOS update
RRamo7
New Contributor III
Hi Frankg63,
Community Manager
Hi Ruben
I have downgrade the 2nd Board to 0163.
But it don`t work.
I have load the Setup defaults via F9 in both Boards.
I set up the USB Standby Power in both Boards.
In the newer Board it don`t work.
This Board work.
Board Information:
Version AAG2378-801
Serial Number:BQMT218003B3
On this Board the USB Standby Power don't work
Version:AAG81515-900
Serial Number:BQMT301003FF
RRamo7
New Contributor III
Hi Frankg63,
Thank you very much for your feedback, we really appreciate that, and that's so weird since it's not working with the newer version.
We will check if there is a fixable workaround for this and let you know.
