Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DN2800MT and IDU 3.2.3.052
Jump to solution
I have installed lastest IDU on new Atom mb DN2800MT but don't show any information or other action are possible.
Only animated circle are show (see picture below)
Any suggestions?
Usefull info of my system:
Intel DN2800MT lastest bios 159
Windows 7 32 bit
All lastest drivers downloaded and installed from support page.
Community Manager
Hello Massimo,
Please proceed to remove the application from "programs and features" and make sure you are installing the following version:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20488&keyword=%22%22intel+desktop+uti... Download Center
Ensure to have the latest Intel(R) Chipset Software Installation Utility from our website as well:
Download Center
Community Manager
Hello Massimo,
Download Center
Community Manager
I have try this new version of IDU but same behavior (infinite round circle).
I have already lastest Intel Chipset Software installed.
On same Windows are installed also:
/Detail_Desc.aspx?agr=Y&DwnldID=20768&lang=eng Intel Desktop Boards">AHCI: Intel® Rapid Storage Technology Driver for Intel Desktop Boards
/Detail_Desc.aspx?agr=Y&DwnldID=21863&lang=eng LAN: Intel® PRO Network Connections LAN Driver for Windows 7*
/Detail_Desc.aspx?agr=Y&DwnldID=21690&lang=eng Graphics: Intel® Graphics Media Accelerator Driver for Windows* 7
All lastest version downloaded from DN2800 web support page.
Tomorrow I try to re-format my hard disk and make a clean windows install with only
chipset inf driver and IDU software.
Community Manager
Hello Dan, Good news!!!
Clean fresh re-formatting and re-installing of Windows resolve the issue.
IDU now work perfectly. The problem were related with previous installation of Windows.
On this new version I note only one behavior (not real problem):
Has processor core voltage alarm set to default at 0.4 Volt and so appear frequently alarm windows of cpu undervoltage that instead are normal because intel SpeedStep
are active and cpu going to lower power usage. Can be easy resolved by lower threshold in option panel.
