We're using the DN2800MT for an embedded application and a problem we're having is that the mother board will provide power to connected usb devices when initially plugged in, before pressing the power button. This behavior is different when compared to the powered off state after a shutdown. In this case all usb devices are powered off, as expected. We plan to use the usb power as a shutdown signal to our embedded boards connected over usb. I can't seem to find any setting to change this behavior in the bios. Any help would be extremely appreciated.
Hi richmondb,
I recommend you clearing the cmos on your board first by removing all other devices and disconnecting the battery for about 20-30 minutes. Once this has been done, please update the bios on your computer to the latest. You can use this link to get the latest bios updates:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=DN2800MT https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=DN2800MT
