Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DP35DP no signal to monitor
DP35dp motherboard running with 7600gt nvidia video card, ocz memory ddr2 667 with 4-4-4-8 timing, and core2duo. The problem is that when i turn on the computer i get a no signal to the monitor, the usb keyboard is not on, nor is the dvd-rom drive. However, all the fans are on, even including the video card fan is on.
Highlighted
New Contributor II
pls remove your ram and power up the system. if the system have beep sounds. you are safe.
so next , you need to instal back your ram into the dual channel memory slots. meaning.. add the rams into the blue slots.. and power up..
if you try the 2 steps above and still can get your pc up, search for the bios reset jumper and reset your bios..
Highlighted
Community Manager
I unplugged the memory, there was no beep, and still had the same problem.
Highlighted
New Contributor II
if you plug the memory and there is no beep
THATS MEANS.. the processor and the Dp35Dp mainboard is not responding .. and they are not looking for the ram.. check your processor whether is it supported in the dp35dp support list.. check for bend LGA775 Pins too...
Highlighted
Community Manager
Thanks, the pins are bent on the motherboard. need to get a new motherboard.
Highlighted
Community Manager
besides, the DP35DP does not support ram with CL4 or voltages other then 1.8V
Highlighted
New Contributor II
try calling intel support.. take a picture of the damage and email to them... let them escalate the issue to the top technical guys whether your board entitle a replacement..
