Hi!
Is there any way to use WDT on Windows7 to automatically restart PC when it hangs?
Hello daredee,
I reviewed the technical specification for this motherboard, but I could not find information that would indicate that this feature is present with this model; however, please follow the steps below in order to check if it is present in your BIOS configuration.
- Enter your BIOS configuration
- Go to the "Performance" tab.
- Look for "Fail save" or " Watchdog Timer".
- Enable it.
When enabled, the Watchdog timer will catch system hangs and/or failures and reset the system when a POST failure is detected. If a failure occurs, the Watchdog Timer assertion should reset the system and boot using default settings as well as display a warning message.
Let me know how it goes.
Amy.
daredee, hope you were able to check my last input.
Amy.
Hi Amy
Thank you
I have no enough time right now to check your advice
dp43bf works in my headless server so I need to do extra moves to reach BIOS settings
daredee, no problem.
Let me know if the results if you are able to reach the motherboard.
Amy.
