Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DP45SG DDR3 1333 scheduled chkdsk on next boot issue
BFG 9800 GT OC 1GB PCIE 2.0 x16 (in primary x16 slot)
Core 2 Quad Q9550 95W
PVS34G133ELK Patriot 4GB kit DDR3 1333 PC 10666
KVR1333D3N9K2/4G Kingston 4GB kit DDR3 1333 PC3 10600 Bought to prove the Patriot ram was not dieing...
BOXDP45SG (OMG WTFH)
Antec Truepower 650W ATX12v V2.3 EPS12v V2.91 SLI XFIRE ORIGINAL POWER SUPPLY
Rocketfish 1000w Bought to prove the antec power supply was not dieing...
2x Hauppauge HVR 2250 PCIE x1 or X8 slot (both in x1 PCIE slots)
I discovered something interesting this weekend while trying track down multiple issues with my DP45SG. Those of you still will this motherboard if you wouldn't mind confirming I would be grateful. Intel support I have not filed an official complaint on this particular issue yet.
  1. Clear CMOS (remove battery for 30 minutes)
  2. Install Patriot RAM above.
  3. no need to install the TV tuner cards so just install the video card.
  4. Bios jumper set to configure mode
  5. Plug in power supply
  6. Warning the settings have been lost answer Y to enter bios and set time etc.
  7. Press F9, press ENTER, press F10, Press ENTER
  8. Warning that I need turn off computer and change jumper
  9. Turn off computer and remove AC power cord wait for green light to go out
  10. Move jumper to normal bios mode
  11. Plug in AC power cord
  12. Turn on computer and wait for Intel splash
  13. Wait to see F2 dialog and start spamming F2 key for bios configuration
  14. Bios configuration screen loads
  15. Press F9, press ENTER, press F10, Press ENTER
  16. computer shuts down and turns off
  17. computer automatically turns back on
  18. see Intel splash
  19. Wait to see F2 dialog and start spamming F2 key for bios configuration
  20. Bios configuration screen loads
  21. configure SATA for ACHI mode
  22. F10 save and exit
  23. see Intel splash
  24. let windows 7 64bit enterprise load
  25. Properties on c: drive
  26. Tools tab
  27. Check now
  28. schedule chkdsk next boot
  29. Restart computer with windows start menu
  30. see Intel splash
  31. see windows start load
  32. see warning about chkdsk press any key to STOP it... start spamming any keys but countdown continues and does chkdsk
  33. computer reboots after chkdsk
  34. windows loads
  35. shutdown windows
Well that's not right!
Go back to step 12 and start over
do step 21, but add the following
Memory configuration manual instead of automatic. change nothing else in the memory settings
continue to step 22
same problem happens at step 32
Well it fails again that is odd...
Memory configuration manual instead of automatic. change from 1333 to 1066. change nothing else in the memory settings
continue to step 22
at step 32 I can cancel the schedule chkdsk
That's more like it, but I am still not happy.
Well maybe its the ram NOT LIKELY!
Back to step 1
At step 2 substitute the other Kingston ram
problem at step 32 happens!
Well crap other people say this ram works better than the patriot for automatic timings. Dang it!
continue to step 22
Well it fails again this is not looking good
continue to step 22
Oh man both sets of ram have the same behavior. This is not good at all. There is defiantly some strange issue with 1333 DDR3 ram it seems to me.
I put the patriot ram back in and put ram timings to manual - 1066.
I was using bios rev 0121 during these procedures.
Can anybody else reproduce this?
Highlighted
Community Manager
Re: DP45SG DDR3 1333 scheduled chkdsk on next boot issue
Guess I blacklisted myself since...
Well for now I am trying another motherboard to prove to myself that a different maker with similar chipset can do the things I can not do with this motherboard. Then at least I can say that all of my other hardware is fine and it is a motherboard problem. We will see how it goes this weekend.
Highlighted
Community Manager
Hi, I have this board with 4 dimms, Kingston KVR1333D3N9. I can work without problems with only 2 dimms on the blue slots. If I use the 4 dimms (8 Gbs) the board starts to freeze or reboots suddently.
Can you tell me the settings to run the ram at 1066Mhz? I have read on other posts that the board has no problems with 8Gbs at 1066Mhz.
