Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DP45SG and Corsair TW3X4G1333C9DHX?
Hi.
Sorry if my english is not allways good.
I have some troubles with my Computer.
I have a:
Mobo: DP45SG
Proc: Q9550 C2Q
Ram: 4GB Corsair XMS3 CM3X2G1333C9
Video: XFX ATI XXX HD4870
PSU: 700W
OS: Win 7 ultimate.
I build this machine like at the middle-end of 2009. I have some trubles with restarts.
Then an actually the Intel Desktop Center is a Beta and I dont believe what it shows, sometimes the temperatures pup in less than a second from 55 to 65º (for example). I think that is because the Beta`s edition. So I start to use another testing temperature programs.
First it restarts evetually I have tried to put different OS like XP, Vista, 7 RC, 7 Ultimate and with all the same problem. Thinking that a bad ventilation affects,, I put more fans. Doesn´t work.
I seein IDCC that the ram temperature gets high and i have buyed a cooler for memory. When I tried to put them it doesnt feet so well because it was for memories without the metallic cover that the corsair TW3X4G1333C9 has. I put them and I brake 1 of the 2 memories because I make too much preasure with the screws of the cooler. I have to put, not too tight, only 1 memory of 2 GB to my machine still work.
Then I search for a processor air cooling and the cooler master V8 was a good choice. Still restarts.
Then I search for a high ventilated chassis and the Cooler Master HAF 922 was a good choice. Still restarts.
The PSU is not bad because its almost new an I have tried it in a computer with similar specs an the same video card and no problem.
With all changes it restarts less times, but the problem continues. When I use the computer for really basic stuff (word, excel, internet), every thing is OK, but wen I start to play games (from counter strike to crysis) it only takes a wile to restart, about 20-30 min. The only thing that continues showing that get`s hot is the ram memory in the IDCC, but li I said I dont really trust in that program. I dont know other program that shows me the temperatures of the memory.
Sick of all that restarts today i have buyed an 8GB (4 x 2GB) corsair TW3X4G1333C9DHX that comes with its own coolers but I have to wait like 15 days to they come to Guatemala.
I see that other people has troubles with this memories in this motherboard. I dont know if I have make a mistake buying this memories?
Does anyone has this memories on your machine?, working good?, someone can give me an advise about other things to try about the restart problem?
Thanks.....
Highlighted
Community Manager
Re: DP45SG and Corsair TW3X4G1333C9DHX?
sorry, I forget that in the case I have put some other 5 80mm fans that the ones that cames with the case/chassis. I think that is over-ventilated (thinking to all that dust that cames in).
Highlighted
Honored Contributor I
The only mem. that will work with this board if you want 1333, is DDR3-1333-10600, if you have mem. with a spec. of 10666 thats your problem. Been there done that .
