Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DP45SG not recognized by Intel Express Installer
So I tried to install the drivers with Intel Express Installer but it simply says that my board is not an Intel's. I manually installed the drivers but I still wanted the software for overclocking and stuffs.
Help me.
Highlighted
Community Manager
Re: DP45SG not recognized by Intel Express Installer
Highlighted
Community Manager
No the Intel Desktop Control Center doesn't work, it says the motherboard is not supported.
Highlighted
Community Manager
Hi there,
Actually, I remember to use IDCC on this board a few month ago. I still have the screenshot showing that it worked fine.
Before installing the software IDCC, update your bios version of the board, preferably use the recovery method or F7 method if present.
Website: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=2932&DwnldID=17617&strOSs=... http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=2932&DwnldID=17617&strOSs=...
Website: http://downloadmirror.intel.com/17617/eng/SG_0116_ReleaseNotes.pdf http://downloadmirror.intel.com/17617/eng/SG_0116_ReleaseNotes.pdf
Website: /docs/DOC-3111 http://communities.intel.com/docs/DOC-3111
Then download the IDCC version IDCC.4.3.0.1198.
Website: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=2932&DwnldID=17579&strOSs=44&OSFull... http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=2932&DwnldID=17579&strOSs=44&OSFull...
Note: this is still beta version.
From the link below:
Website: http://downloadmirror.intel.com/17226/eng/Readme.txt http://downloadmirror.intel.com/17226/eng/Readme.txt
After installing Intel Desktop Control Center 4.4.0, if you encounter issues that are not documented below, please send an email to mailto:idccfeedback@intel.com idccfeedback@intel.com and attach the following file:
C:\PROGRAM FILES\INTEL\INTEL(R) DESKTOP CONTROL CENTER\LOGS\IDCC.LOG (for 32-bit OS)
C:\PROGRAM FILES(x86)\INTEL\INTEL(R) DESKTOP CONTROL CENTER\LOGS\IDCC.LOG (for 64-bit OS)
and include a screen shot of the error message.
Please also include your BIOS version, OS version (Windows XP or Windows Vista; 32- or 64-bit), and OS language.
Hope this helps a bit. Let us know how it goes.
Kind Regards,
Aryan
Highlighted
Community Manager
So I upgraded my bios but it still doesn't work and I don't have any log since it doesn't install. Really strange.
