Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DP55SB board
Hi!
I am setting up a DP55sb board and i5 750 processor, which only powers up one time and then I must remove the battery to get it to start up again. This is happening every time.. Board has been removed from chassie and does the same on the bench.. I have changed 3 different kinds of ram sticks (and without any sticks), 2 different power supplies still same. When i try graphics board (2) It won't power up even the 1st time. I would like to know if Im overlooking something or if the board or processor is defective. Anyone who could help me I would be grateful.
Pete
Highlighted
Honored Contributor I
Do you have the SATA power connector at the bottom of the board Fig.30 item B . ???
Highlighted
This conntection is what powers the graphics.
Highlighted
Community Manager
considering that the external connectors are the top. Yes sata connectors are the bottom left. I don't know where to look for figure 30.
Thank u for responding.
Highlighted
Community Manager
I have tried two ASUS "ENGT 430" graphics boards- 1GB DDR3. but even without the board at all it won't restart w/o pulling the battery??
