Intel® Desktop Boards
Peer-to-peer support only
11434 Discussions
DP55WB restarts problem
PVasi2
Hello everybody.
I have a problem six months. I can't use restart because every time i receive two beeps and no signal. I found a solution. Shut down - change cmos jumper to configuration - turn on save and exit - shut down and turn on again. I update bios to WBIBX10J.86A.0336.2012.0626.0141 - change bios battery - tried different memories - tried other gpu but problem still remains... Now its time to fresh windows and that means lots of restarts.
My setup: MB DP55WB
CPU Intel i5 750 2.67
GPU Sapphire radeon 7870 2gb oc
RAM Corsair xms 2x4 1333
Any help will be well come
PVasi2
Hardware activity can be done. So... Anyone around with knowledge?
Allan_J_Intel1
Have you tried different power supply?
Do you have same issue with an earlier BIOS version?
File name: https://downloadcenter.intel.com/downloads/eula/20839/BIOS-Update-WBIBX10J-86A-?httpDown=http://down... WB0333P.BIO
Allan.
PVasi2
Unfortunately yes... I had the same problem with that version.
I tried many power supplies.
I think its hardware problem. Maybe something burned? but i don't know that to replace.
