Intel® Desktop Boards
Peer-to-peer support only
Intel Customer Support will be observing the Martin Luther King holiday on Monday, Jan. 17, and will return on Tues. Jan. 18.
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
11380 Discussions
DP55WG Second RAID Controller
Community Manager
I tried to put my HighPoint RocketRAID 1740 controller card in my DP55WG Desktop board, but it's a no go. The computer turns on, shows the Intel onboard RAID BIOS. Then the splash screen (where you press F2) comes up for a brief second and is replaced by the HighPoint BIOS scanning for devices. After it finishes its scan, the screen goes black with a blinking cursor in the upper left hand corner and never gets any further. The weird thing is that I cannot get into the BIOS setup (by pressing F2). I called Intel and they told me that alternate RAID controllers are not supported on this motherboard. When I was searching, I came across this: /message/81080?tstart=0 http://communities.intel.com/message/81080?tstart=0. It looks like this guy has a second RAID control card. I would like to know if there is anyone out there that has a second RAID controller card working with a DP55WG motherboard. What kind of card? Any tricks to get it working? Thanks.
Salem_W_Intel1
Hi!
You could increase the Hard Drive Pre-Delay (see this under Advanced/Drive Configuration submenu) in the BIOS to, say, 5 secs. Please, try this with the BIOS Configuration jumper set to Maintenance (Configuration) Mode:
http://download.intel.com/support/motherboards/desktop/dp55wg/sb/dp55wg_configlabel.pdf
