Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
DP55WG, Windows 7x 64 ultimate, Processor Intel Core i7_870_2.93GHz, and 2 Memory PATRIOT (PGV34G1600ELK)_DDR3_1600mhz_1.65v of 2GB each one. And I have bought 2 Memory kingston HYPER (HX316C10FR/4)_DD3_1600mhz_1.5v of 4GB each one, to add. Total I would
AAzar3
DP55WG, Windows 7x 64 ultimate, Processor Intel Core i7_870_2.93GHz, and 2 Memory PATRIOT (PGV34G1600ELK)_DDR3_1600mhz_1.65v of 2GB each one. And I have bought 2 Memory kingston HYPER (HX316C10FR/4)_DD3_1600mhz_1.5v of 4GB each one, to add. Total I would have 12 GB, but kingston memory doesn´t work anyway, alone or together.
HELP!
Thanks in advance!
AlHill
n_scott_pearson
Super User Retired Employee
This board does not have the ability to independently control the voltage for each memory channel. All DIMMs must operate at the same voltage. Further, while memory requiring voltages other than 1.5V is supported, it is not recommended.
AChes
DP55WG has memory controller integrated in processor. First generation of Intel Core i3/i5/i7 processors supports only double sided 4G memory modules. These modules has two rack 2Rx8 organization. Each rack has eight 256Mbit FPGA chips. You can visually distinguish them. These 4G modules have 8 chips at each side. Most of modern 4G memory modules are single sided incompatible with DP55WG. Double sided 4G modules are not produced now so it difficult to find and buy them. The example of double sided 4G module available on market now is Kingston KVR16N11/4. It is compatible with DP55WG. See specification http://www.kingston.com/datasheets/KVR16N11_4.pdf http://www.kingston.com/datasheets/KVR16N11_4.pdf Recently (few days ago) I tested KVR16N11/4 with my DP55WG board. It works fine.
Community Manager
Hi all,
Thanks for the feedback, Savmu as they say, there are some Memory Requirements.
On this table, you can find Supported Memory Configurations on this board.
Hellen.
AAzar3
Thank you very much. All answers helped me a lot. My problem was resolved.
Community Manager
Hi Savmu,
Do not hesitate to contact us back, if there is anything else you need
Hellen.
