Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
DP67BA motherboard can't get in BIOS after overclock
User1581770957783225
Hi, I'm using intel desktop board DP67BA. I tried to overclock RAM in BIOS. I just touched RAM clock, not touched about timing at all but my computer doesn't get to even BIOS after that. I tried to reset CMOS by discarding mercury battery for 1 hour bot not worked. I tried to remove BIOS setup jumper, plug in USB which bios file included but not worked too. How can I recover BIOS from my board?
AlHill
What is you processor model number?
Does the board boot otherwise?
Doc
I'm using i5-2500K processor.
I can't boot board by any way.
AlHill
Do you know what bios you had or have now?
Is the i5-2500K something you just added?
Do you have another graphics card you can test with?
Can you test with only one dimm?
In this thread, Scott has a 25 step procedure (for another board). https://forums.intel.com/s/question/0D50P00004VhEOFSA3/how-to-upgrade-dz75ml45k-bios-from-0006-to-00...
Adapt this procedure for your board and bios, and follow it exactly. Do not shortcut or skip any steps. It may work, it may not.
Doc
Thanks a lot. I'll try that process with only one dimm and graphic card. Since this board not supports internal graphic, I'll test with graphic card plugged in. I had BA0082 bios before problem.
I tried it, but I'm stuck in step 13. I'm leaving my system powered on for almost 20 minutes, but nothing shows on screen.
AlHill
Ok, I suggest you wait for @n.scott.pearson​ to look at this. He may be on travel now, so just hang in there.
Doc
Also, I tried to boot by from step 14, but not worked at all. Does the only way to fix board is to flash bios chip manually?
AlHill
Files to flash the chip are never provided. If you purchased such a chip of the net, you are getting some other board's information, MAC addresses, and such. I do not recommend you do this.
Doc
Oh I can't even flash chip manually by bio file?
AlHill
You can, if you can find a .ROM file, which Intel never provides due to security concerns.
If you have roached the board, you may want to try and find one on the used market
Doc
AlHill
Also, the latest bios for your board is 0083. The release notes can be found here:
https://web.archive.org/web/20191119132110/https://downloadcenter.intel.com/download/28294/BIOS-Upda...
I have attached the latest bios in case you do not have it.
Doc
AlHill
One more question - do you happen to have another processor to test with?
Doc
Yes. I have a lot of sandybridge processors, but I don't have new thermal greeze now. For new thermal greeze, I have to wait until 02-18.
AlHill
You should be able to try another processor without paste and fan, just to see if the bios appears. You would not be running it for long.
Doc
Test with G2020,
1) without connecting fan, bios cfg jumper plugged = infinite loop 10 secs on and off
2) connected fan, bios cfg jumper plugged = on but no screen
3) connected fan, bios cfg jumper unplugged, usb bios file included = infinite loop 10 secs on and off
Can you feel something? If you need, I can try with another processor
AlHill
No, nothing that I can think of.
Doc
G2020 Ivy Bridge processor with connected fan, bios cfg jumper unplugged, plugged usb bios file included now not reboots. Can it be bios recovery process? Do you suggest me to wait?
AlHill
Well, maybe one more thing - have you tried another power supply?
Doc
Sadly, I don't have another power supply that can use for this system now. I only have a lot of sandy/ivy bridge processors, two graphic cards and 4 rams.
AlHill
The only thing left to try is the power supply. Other than that, I have no ideas. The one guy who might be able to help is on travel, so you will have to wait.
Doc
