Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DP67BG. Nvidia GTX 460 wont display 2nd montior.
Here is my setup;
Intel DP67BG
Intel Core i7 2700k
16gb Corsair Vengeance DDR3 1600mhz
Asus Gtx 460 1gb
Antec EA650 650w power supply
2 Hard drives (both sata2).
For some reason, I cannot get the 2nd monitor to work with my video card. The card works fine in other systems, but windows will not recognize when I have 2 monitors plugged into my video card. I am using the 2 dvi ports and have tested with different cables and monitors. I have pin pointed it down to the motherboard.
Any ideas on what could be wrong?
Highlighted
Community Manager
It's not likely to be a motherboard problem since there's no video ports on it.
It's either the drivers for your video card, the connections to the card or the dual monitor options you set in Windows.
