Intel® Desktop Boards
Peer-to-peer support only
11432 Discussions
DP67BG SATA port problem?
Community Manager
I'm noticing errors on my (very old) DP67BG SATA ports as of late, particularly under heavy SATA usage.
Might this be due to the 6-series chipset error (which this MB exhibits)?
System is running Ubuntu 12.10 64-bit.
Example errors follow.
Gary
Nov 25 01:07:52 powerspec kernel: [ 2081.561802] ata3.00: exception Emask 0x52 SAct 0x7 SErr 0x880d00 action 0x6 frozen
Nov 25 01:07:52 powerspec kernel: [ 2081.561808] ata3.00: irq_stat 0x08000000, interface fatal error
Nov 25 01:07:52 powerspec kernel: [ 2081.561813] ata3: SError: { UnrecovData Proto HostInt 10B8B LinkSeq }
Nov 25 01:07:52 powerspec kernel: [ 2081.561817] ata3.00: failed command: READ FPDMA QUEUED
Nov 25 01:07:52 powerspec kernel: [ 2081.561826] ata3.00: cmd 60/80:00:31:1b:32/00:00:22:00:00/40 tag 0 ncq 65536 in
Nov 25 01:07:52 powerspec kernel: [ 2081.561826] res 40/00:04:31:1b:32/00:00:22:00:00/40 Emask 0x52 (ATA bus error)
Nov 25 01:07:52 powerspec kernel: [ 2081.561830] ata3.00: status: { DRDY }
Nov 25 01:07:52 powerspec kernel: [ 2081.561834] ata3.00: failed command: READ FPDMA QUEUED
Nov 25 01:07:52 powerspec kernel: [ 2081.561841] ata3.00: cmd 60/80:08:b1:1b:32/00:00:22:00:00/40 tag 1 ncq 65536 in
Nov 25 01:07:52 powerspec kernel: [ 2081.561841] res 40/00:04:31:1b:32/00:00:22:00:00/40 Emask 0x52 (ATA bus error)
Nov 25 01:07:52 powerspec kernel: [ 2081.561845] ata3.00: status: { DRDY }
Nov 25 01:07:52 powerspec kernel: [ 2081.561849] ata3.00: failed command: READ FPDMA QUEUED
Nov 25 01:07:52 powerspec kernel: [ 2081.561857] ata3.00: cmd 60/08:10:11:9e:c0/00:00:03:00:00/40 tag 2 ncq 4096 in
Nov 25 01:07:52 powerspec kernel: [ 2081.561857] res 40/00:04:31:1b:32/00:00:22:00:00/40 Emask 0x52 (ATA bus error)
Nov 25 01:07:52 powerspec kernel: [ 2081.561861] ata3.00: status: { DRDY }
Nov 25 01:07:52 powerspec kernel: [ 2081.561867] ata3: hard resetting link
Nov 25 01:07:52 powerspec kernel: [ 2081.561885] ata4.00: exception Emask 0x52 SAct 0x1 SErr 0x880d00 action 0x6 frozen
Nov 25 01:07:52 powerspec kernel: [ 2081.561886] ata4.00: irq_stat 0x08000000, interface fatal error
Nov 25 01:07:52 powerspec kernel: [ 2081.561887] ata4: SError: { UnrecovData Proto HostInt 10B8B LinkSeq }
Nov 25 01:07:52 powerspec kernel: [ 2081.561888] ata4.00: failed command: READ FPDMA QUEUED
Nov 25 01:07:52 powerspec kernel: [ 2081.561891] ata4.00: cmd 60/80:00:b9:1b:32/00:00:22:00:00/40 tag 0 ncq 65536 in
Nov 25 01:07:52 powerspec kernel: [ 2081.561891] res 40/00:04:b9:1b:32/00:00:22:00:00/40 Emask 0x52 (ATA bus error)
Nov 25 01:07:52 powerspec kernel: [ 2081.561892] ata4.00: status: { DRDY }
Nov 25 01:07:52 powerspec kernel: [ 2081.561893] ata4: hard resetting link
Nov 25 01:07:52 powerspec kernel: [ 2081.879125] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 25 01:07:52 powerspec kernel: [ 2081.879149] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 25 01:07:52 powerspec kernel: [ 2081.890816] ata3.00: configured for UDMA/133
Nov 25 01:07:52 powerspec kernel: [ 2081.903045] sd 2:0:0:0: [sdb]
Nov 25 01:07:52 powerspec kernel: [ 2081.903049] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Nov 25 01:07:52 powerspec kernel: [ 2081.903052] sd 2:0:0:0: [sdb]
Nov 25 01:07:52 powerspec kernel: [ 2081.903054] Sense Key : Aborted Command [current] [descriptor]
Nov 25 01:07:52 powerspec kernel: [ 2081.903058] Descriptor sense data with sense descriptors (in hex):
Nov 25 01:07:52 powerspec kernel: [ 2081.903060] 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
Nov 25 01:07:52 powerspec kernel: [ 2081.903069] 22 32 1b 31
Nov 25 01:07:52 powerspec kernel: [ 2081.903074] sd 2:0:0:0: [sdb]
Nov 25 01:07:52 powerspec kernel: [ 2081.903076] Add. Sense: No additional sense information
Nov 25 01:07:52 powerspec kernel: [ 2081.903078] sd 2:0:0:0: [sdb] CDB:
Nov 25 01:07:52 powerspec kernel: [ 2081.903080] Read(10): 28 00 22 32 1b 31 00 00 80 00
Nov 25 01:07:52 powerspec kernel: [ 2081.903088] end_request: I/O error, dev sdb, sector 573709105
Nov 25 01:07:52 powerspec kernel: [ 2081.903128] sd 2:0:0:0: [sdb]
Nov 25 01:07:52 powerspec kernel: [ 2081.903130] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Nov 25 01:07:52 powerspec kernel: [ 2081.903132] sd 2:0:0:0: [sdb]
Nov 25 01:07:52 powerspec kernel: [ 2081.903133] Sense Key : Aborted Command [current] [descriptor]
Nov 25 01:07:52 powerspec kernel: [ 2081.903136] Descriptor sense data with sense descriptors (in hex):
Nov 25 01:07:52 powerspec kernel: [ 2081.903138] 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
Nov 25 01:07:52 powerspec kernel: [ 2081.903147] 22 32 1b 31
Nov 25 01:07:52 powerspec kernel: [ 2081.903151] sd 2:0:0:0: [sdb]
Nov 25 01:07:52 powerspec kernel: [ 2081.903153] Add. Sense: No additional sense information
Nov 25 01:07:52 powerspec kernel: [ 2081.903155] sd 2:0:0:0: [sdb] CDB:
Nov 25 01:07:52 powerspec kernel: [ 2081.903165] Read(10): 28 00 22 32 1b b1 00 00 80 00
Nov 25 01:07:52 powerspec kernel: [ 2081.903171] end_request: I/O error, dev sdb, sector 573709233
Nov 25 01:07:52 powerspec kernel: [ 2081.903201] sd 2:0:0:0: [sdb]
Nov 25 01:07:52 powerspec kernel: [ 2081.903203] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Nov 25 01:07:52 powerspec kernel: [ 2081.903204] sd 2:0:0:0: [sdb]
Nov 25 01:07:52 powerspec kernel: [ 2081.903206] Sense Key : Aborted Command [current] [descriptor]
Nov 25 01:07:52 powerspec kernel: [ 2081.903208] Descriptor sense data with sense descriptors (in hex):
Nov 25 01:07:52 powerspec kernel: [ 2081.903210] 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
Nov 25 01:07:52 powerspec kernel: [ 2081.903219] 22 32 1b 31
Nov 25 01:07:52 powerspec kernel: [ 2081.903223] sd 2:0:0:0: [sdb]
Nov 25 01:07:52 powerspec kernel: [ 2081.903225] Add. Sense: No additional sense information
Nov 25 01:07:52 powerspec kernel: [ 2081.903227] sd 2:0:0:0: [sdb] CDB:
Nov 25 01:07:52 powerspec kernel: [ 2081.903228] Read(10): 28 00 03 c0 9e 11 00 00 08 00
Nov 25 01:07:52 powerspec kernel: [ 2081.903235] end_request: I/O error, dev sdb, sector 62955025
Nov 25 01:07:52 powerspec kernel: [ 2081.903245] ata3: EH complete
Community Manager
You can download a Windows utility which will detect whether your motherboard has the SATA bug:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20034&lang=eng Download Center
Community Manager
Thanks, but I had done so, and it does have the (potential )SATA degradation flaw.
I was wondering whether the errors I'm seeing are due to that or something else, as the flaw does not always manifest itself on all systems.
Gary
Community Manager
You might want to run a disc diagnostic specific to your brand of hard discs. Western Digital calls theirs Data Lifeguard and Seagate calls their SeaTools, both are run from a bootable CD or possibly a bootable USB stick. I've had discs fail in the past, it usually starts with a file can't be read, longer than usual boot times, the worst is when the click of death or chattering happens.
If your board does have the B2 stepping and the SATA utility says your board is effected, probably best to just get rid of it. But 1st check to see if you just have a misbehaving disc.
http://www.intel.com/support/chipsets/6/sb/CS-032521.htm Intel� 6 Series Chipset — Chipset circuit design issue identified
