Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
DP67BG does not accept more than one ram stick
RWaet
gstHey,
my main board is doing everything do drive me crazy.
Maybe someone has an idea whats wrong and how to fix it.
My System,
MB DP67BG
Core I5 2500K
Radeon HD 4870
So the Problem:
I wanted to upgrade my ram from 2x2GB to 2x2GB and 2x4GB (2GB sticks Kingston KVR1333D3N9K2/4G, 4GB sticks Kingston KVR1333D3N9/4G)
The System worked fine with 2x2GB sticks in DIMM1 and 2 (the blue ones)
I changed the 2GB into 3 and 4 (the black ones) and put the 4GB into 1 and 2 (the blue ones)
The Motherboard gave me some error Messages basically saying there is a Problem with ram. I think it was error 28? but I am not sure. So I updated the BIOS to the newest Version hoping that would help, but it didn't. I also made a reset of the bios, both with the Pins and the battery did not help.
Only the error changed to 27 when I have more than 1 stick of ram in the Mainboard.
So the Status now is,
I can put 1 stick of ram into the first Slot and it works (every ram stick works)
As soon as I put another ram (additional to stick in Slot 1) into the 2 or 4 Slot i receive three beeps and error message 27 and the pc restarts after about 3sec.
When ,I additionally to stick in 1, put a stick in Slot 3 the pc starts but does not find the extra ram.
When I put a stick into 2,3 or 4 alone it does not work (error 27)
My BIOS Memory Settings are set on automatic means 1333 9-9-9-24 1,5V that is what the ram is supposed to have.
I tried with 1,65V but didn't make any difference.
So I really somebody has an idea how to fix it as I really want the extra ram.
cheers,
Robert
JWebb2
I had a problem a bit like this & got it resolved - does this help:
JWebb2
RWaet
Thanks, I tried it. But had no luck.
I updated the BIOS before to 22009 so I wasn't able to install the 1979 and both of the other firmwares gave me an error message while installing.
Silvia_L_Intel1
Robert,
Try a BIOS recovery to version 2161, since this version fixed some memory issues. https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20931&lang=eng&OSVersion=%0A%09%09%0...
The following link will show you how to rollback to a previous BIOS version:
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS update
Then update to version 2185 and test the board https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21293&lang=eng&OSVersion=%0A%09%09%0...
RWaet
Thanks for the advice.
the recovery to 2161 worked flawless, had to use also the recovery function to update to 2185 but worked as well.
Unfortunately still the same error as before.
Silvia_L_Intel1
Robert,
We already cover all possible troubleshooting, so feel free to contact your local Intel support group for assistance on replacing your product: http://www.intel.com/p/en_US/support/contactsupport?group=processor http://www.intel.com/p/en_US/support/contactsupport?group=processor
