Community
cancel
Showing results for
Search instead for
Did you mean:
ADoka
DP67BG impossible to wake up. Wake on LAN and RTC doesn't work.
cHello, could somebody explain me, how to wake up this board? (DP67BG)
I try to wake up several programs with wake on lan through MAC address, my router built in wake on function, and real time clock wake up too but it's failed.
I have win 8.1 with latest security fixes, latest intel LAN driver (but I don't think it's matter when RTC wake up set in BIOS) but nothiing happend.
I have the latest BIOS etc ... Here is my screenshoots:
My bios version: https://mega.co.nz/# !HEIAALIL!G0XyW1XssYO62Vgme1_IMpUr9fQW_feiFnidtqsCPfY MEGA
My power settings in BIOS: https://mega.co.nz/# !iFJR2YgL!1b7kJd0oKO0oRx4UvUhFWJzS9LSyYC8GiXIx_56ljqc MEGA
My driver version in W8.1pro: https://mega.co.nz/# !XJgljLgb!bLIz4H90luYyIGsfSCr5RpOzepdKZEbZIkEL1twDIVE MEGA
My driver special settings in W8.1: https://mega.co.nz/# !LEQWXDwS!DdJr9yTR0w1dLytiCQujAiZyIvkBTBaGjU4HYJZ87HY MEGA
and my driver power setting in w8.1: https://mega.co.nz/# !bcQBia4A!XSMLhwWrAqDS56Q6E0WoXAzGRBvrsuSIrdHGi2ymzlI MEGA
Can someone help me, what went wrong?
BUT, the bios in power setting set to wake up computer every day at 7am, but nothing happend.
With best regards
Andras.
Kevin_M_Intel
Hi Andrew_Doka,
I am sorry to hear you are having problems but let me help you.
What software are you using to wake up the board? Can you also post your dxdiag report here?
How to get it?
Dxdiag Report: Type dxdiag in Start Menu> open> Save> Copy/Paste here.
ADoka
Thank You, but please help my understand what do You think on your mind? I talked about a BIOS setting that mean on a first setting before loading the operathing system. I am not a genius, but please help me to understand, if I set on a working computer's bios to powering on every day at 7am why do You need a Microsoft Directx diagnostic information (what is a graphic subsystem in windows and availadle on a powered on system!) to testing this problem on your lab?
I think it MUST BE without hdd, like i press the power button. And if i use fedora, or redhat, what information do You NEED AFTER BOOT, SO WHEN THE POWER ON WAS HAPPEN? Please ...
ADoka
Please talk about my second screenshot, the bios power settings.
I set that WAKE ON LAN from s4/s5 WITH DEEP S4/5 Disabled. For me this means that the board can wake up for a WAKEONLAN frame.
State indicator is a usefula feature
than I sate that WAKE FROM S5 means the mother will wake by his own real time clock
wakeup date=0 means EVERY day
wakeup hour=7 means seven am
pcie aspy means you dont got help in bios
So why cant start a board for example without hdd and operating system every day at 7am. If I would like a build a diskless client with live linux pxe boot ???
Hlease help me. BUT I have an Idea, I don't know why but today the computer was started at mornig. Can You check che corrent setting in BIOS? For example that setting wakeup hour means wakeup day? Is it possible?
With Best Regards.
ADoka
Hello, so as I promise, here is Your requested directx log:
https://mega.co.nz/# !J9ZFkBwZ!9Iz3sYe_IfdHRAC-Y5CoA2WGbsCC4KpwSwDYMFoX9Pc MEGA
(But, not only this motherbork can't wake up by rtc. My oldest one dp55kg aren't.)
Kevin_M_Intel
Thanks for the feedback. Let me check this information and settings from my side and I will be back with more information.
Kevin_M_Intel
Hi Andrew_Doka,
Sorry for the delay. I would like to confirm with you something about the configuration. Was there any change on the system when it worked? Did you change the parameters at the BIOS level? Besides this, can you try installing the management engine driver? Here is the download link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21764&ProdId=3273&lang=eng&OSVersion... https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21764&ProdId=3273&lang=eng&OSVersion...
MFied1
some other Intel boards released around the same time have an issue with WOL while running drivers higher than v16.8.1
I had the same issue with DP55KG, and it applies also to DP55SB, DP55WG. The solution has been confirmed on one of the threads here on this board....
64bit:
ftp://208.73.49.24/pub/misc/drivers/intel/PROWin7_64_v16.8.1.exe ftp://208.73.49.24/pub/misc/drivers/intel/PROWin7_64_v16.8.1.exe
if this ftp becomes not functional, look for: PROWin7_64_v16.8.1.exe
1> uninstall the ( most likely newer ) drivers.
2> install 16.8.1
3> in the device properties enable WOL from S5 ( or from power off )
after the shutdown WOL wakes up the system.
took me about 10 days to find out that upgrading / downgrading the BIOS is not the solution......
Good Luck!
Mike
AR14
Finally a solution that might work.
The ftp asks for username and password and Ive searched everywhere on the web for that driver v16.8.1 with no luck.
Can you upload that driver v16.8.1 somewhere so i can download it ?
