Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
DP76BG network adaptor not working
JWebb2
Yet more grief from this board (over a month now, one thing after another)
Finally got to a stage where I loaded Windows 7 64bit but can't get network connectivity. Installed the LAN driver from the CD provided. I have managed to ping my router a couple of times, but this doesn't last. Windows reports no cable. There is a cable & the cable is OK. Tried another known good cable. Same problem.
Tried with Vector Linux live disk and still no connectivity so not a Windows problem.
Then tried downloading the driver from Intel & still no joy.
It appears that the system is trying to initialise the LAN adapter as the green socket LED lights up for a period then goes out for a period. During this cycle, Windows is trying to do something but can't.
Community Manager
Hello Jonathan,
Here are our recommendations for this issue:
- Make sure you have the latest Chipset and LAN driver from our website:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine... Download Center
-Check for any conflicts in device manager. .
- Test with a peer to peer connection with another computer using a cross-over cable.
-Update your motherboard BIOS to the latest version available:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21687&lang=eng&OSVersion=&DownloadTy... Download Center
Please be sure to read and follow all accompanying instructions, which can be found at this link:
http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm Desktop Boards — BIOS update instructions
If the issue still persists, test the system out of the chassis and proceed to replace the board under warranty.
JWebb2
Dan,
I AM NOT A HAPPY BUNNY.
Finally managed to make time to go through your recommendations (I have a living to make & a family to interact with) BUT when I came to turn the PC on & it stops at the code 27 loop. Web searching suggests this is back to the problem I had in the first place (/thread/40039 http://communities.intel.com/thread/40039). This was working fine. And now it's not. What a POS these boards are - demonstrated by having problems with two boards (my experience is that with 2 out of 2 boards giving problems, they're 100% unsatisfactory), and clearly many others have had similar problems.
JWebb2
Now I've suddenly got a red CPU overheat LED on - before the CPU has even a chance to overheat. No boot, no nothing. Was OK before.
Two weeks ago I bought components for a 3rd PC build. I assembled that & loaded the OS and it is now in use. This is how it should be. Not two months later having wasted hours taking the board in & out of the case, updating the BIOS & 101 other things AND STILL HAVING NO BOOT even, let alone a working AND PRODUCTIVE pc.
JWebb2
How do I go about replacing the board under warranty?
Silvia_L_Intel1
hello Jonathan,
You may want to contact your local Intel support group for assistance on replacing your product if it is still under warranty http://www.intel.com/p/en_US/support/contactsupport?group=process http://www.intel.com/p/en_US/support/contactsupport?group=process
Regards.
