Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
DQ35JOE mainboard, Installed a HD7850 and I get this "A bootable device has not been detected.rom the FV]
The latest BIOS is installed and the SATA drive has been connected and disconnected with no difference. System stops with that message. The video card has been put into another system with a different board and does work without issue.
Mainboard Intel DQ35JOE
Video Card: Radeon HD7850 2GB
500W Power supply.
The latest BIOS revision is 1143, should have included that in the post.
Highlighted
After resetting BIOS to optimal defaults, I can now consistently get the Intel boot screen but the system freezes at 5A
Highlighted
Community Manager
Please try to boot without GFX Card ,possibly this board has VGA, OR DVI-I built-in ,
connect the data cable to your SATA Drive if boots Normally , then your GFX CARD either has problem or Not Matching BEFORE DOING THE ACTUAL WORK GO TO BIOS SETUP TO LOAD DEFAULT BIOS
HOPE YOU WILL DETECT AND SOLVE
ThanX
