Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
DQ35MPE motherboard audio issue
Sir, I have Intel DQ35MPE motherboard and I am using windows 10. I have a problem with audio driver. My motherboard is running good with my previous windows 7 when I upgrade my computer with windows 10 32bit recently I didn't get audio from my computer. In my computer sound icon was showing that no audio device is installed. I tried to download and run realtek driver 6201 as my motherboard from https://drivers.eu/Mainboards/INTEL/DQ35MP
but it's not working. Please Can you please help me what is the best driver for my motherboard.
Highlighted
You should never use these 3rd party download sites.  You never know what payload they contain, and where your information is sent.
Your board and processor are long since discontinued and not supported on Windows 10.  Did you go to realtek and look for a driver?
Highlighted
Yes, sir I tried to find out in realtek official website but I couldn't get any audio driver for my motherboard. Sir, I am using 2 hdd in my computer. For the audio issue with windows 10 pro, I install Windows 7 pro in my second hdd but the audio driver issue is still same. Please help me for this issue.
Highlighted
Super User Retired Employee
If you cannot find a driver on the RealTek site for the ALC268-GR audio codec, then you may be out of luck. You can purchase USB-based audio solutions fairly cheaply. For example, these works fairly good and are dirt cheap: https://www.amazon.com/dp/B00IRVQ0F8.
Hope this helps,
Highlighted
Sir, can you please provide me the original audio driver link for my Intel DQ35MPE motherboard. Sir, my motherboard sounds is previously works good before format my computer.
Sir, can it is possible for the old BIOS, I didn't update my computer BIOS since my new computer.
Highlighted
Do a good search on the net for "AUD_allOS_6196_PV_RTL.exe".  I am sure you will find it.
Highlighted
Sir, I download and installed on my computer "AUD_allOS_6196_PV_RTL.exe "but the audio issue is still same.
Highlighted
"can you please provide me the original audio driver link for my Intel DQ35MPE motherboard"
You asked for it.  That it does not work should be expected.
Save yourself time and frustration, and get new hardware.
Highlighted
The original audio driver was for Windows XP. It might support Windows 7, but it is definitely NOT going to work on Windows 10.
Your choices are:
  1. Attempt to get a Windows 10 driver through RealTek. Don't get your hopes up.
  2. Use a simple USB audio device. These are fairly cheap. For example, this one works fairly well (I have a couple and use them all the time) and cost very little: https://www.amazon.in/dp/B06XWJTHBL.
  3. Use a PCI audio card. These can cost a little more. Here's an example: https://www.amazon.in/dp/B01MRUH2MW,
Hope this helps,
