Hi there, I have a problem with this board since i changed settings in the BIOS of this board. What happens is when i turn the computer on the red amt light comes on, fans spin then AMT light goes off then the computer.
It stays on for about 3 secs. Can you help me.
I Have already tried:
- Changing CPU
- Changing RAM
- Taking CMOS battery out (For 5 Hours)
- Changing Power supply
- An taking out most of the components( When i take out the 4 pin power the board works, but i know it won't boot) (also when the ram is taken out it works normally and beeps)
System Specs:
- Core 2 Duo E6300
- 2 GB (was 4)
- 500W power supply
- Nvidia Quadro FX3800
- 1TB HD
- Windows 8.1
Do you remember what settings were changed in BIOS?
Did you try reloading default settings or a BIOS recovery?
You may also try moving the BIOS jumper to configuration mode for the maintenance menu to appear. See pages 59-61 of the Technical Product Specification.
http://downloadmirror.intel.com/16958/eng/DQ45CB_TechProdSpec.pdf http://downloadmirror.intel.com/16958/eng/DQ45CB_TechProdSpec.pdf
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS Update
http://www.intel.com/support/motherboards/desktop/sb/CS-020304.htm Desktop Boards — BIOS Settings Glossary
1. I changed ram overclock settings
2. can't do that because the computer only stays on for 3 secs and turns on again (It repeats)
3. same ^^^^^
Did you try booting with only one memory stick?
Yes
For more complete information about compiler optimizations, see our Optimization Notice.
