Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
DQ45EK - ICHR10 Raid doesn't allow >2TB discs??
Pde_K
I use my DQ45EK as homeserver board, and it has 3 x 1TB drive connected in RAID 5 mode. This works well.
I need more space, so I bought 3 3TB drives, and tried setting them up in Raid 5. Unfortunately they all show up as 746GB instead of 3TB.
When I run in normal AHCI mode, they do show up fine.
I tried the latest Rapid Storage drivers, but they did not allow me to create raid volumes from within windows (8 or 2012). I found a version linked from the dq45ek page and that did allow me to create a volume from within windows. However, it also did not let me create something bigger then 2 x 746GB.
It mentioned specifically that the Option ROM was too old to support >2TB drives. Further searching on the internet shows that you need a option rom with 10.6+, while this option rom (from latest bios 1333) is only 8.x
So, I am wondering, what options are left?
Is there a beta bios available with a new OROM? Is there a way to hack the bios to include a new OROM? Or is the only option now to switch to 2TB drives or buy a new mobo?
Silvia_L_Intel1
Hello Peter,
First of all, I would like to inform you that this motherboard has been out of support since December, 2012.
http://www.intel.com/support/motherboards/desktop/sb/CS-033901.htm http://www.intel.com/support/motherboards/desktop/sb/CS-033901.htm
Also, Windows 8 is not a supported operating system for this specific motherboard therefore; there are no plans for making drivers. http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm
However please let me know which is the current BIOS version of your motherboard?
Could you please include the hard drive model number and the memory you are using?
