Intel® Desktop Boards
Peer-to-peer support only
DQ67EP question
JGibs3
Does anyone know if the DQ67EP's secure boot works with Windows 10? I know the DH61DL's don't (it can be enabled in the BIOS but msinfo32 says Secure Boot State = No).
n_scott_pearson
Super User Retired Employee
Well, let's look at the facts:
  • The DQ67EP board was released in Q1 of 2011.
  • Windows 10 was not released until Q2 of 2015.
  • Windows 10 is not listed as a supported O/S for this board.
  • According to the BIOS release notes, nothing major has been done to the BIOS since 2012.
Based upon this, I would be willing to bet that the board's Secure Boot feature has never been tested with Windows 10.
Bottom line, if it didn't work with the DH61DL -- and you were doing it properly -- it's unlikely that it will work with the DQ67EP. Further, since both of these boards are in the end-of-life and end-of-interactive-support states -- and Intel has exited the Desktop Boards business altogether -- if the feature is broken, there is absolutely zero chance of it being fixed (there's simply no one left to do it).
Sorry,
JGibs3
Well I feel like an idiot. On the DH61DL boards I've tested I enabled the SecureBoot but it always showed is as Off in msinfo32. But looking at the Secure Boot settings in the BIOS, everything was installed except the Intel Platform Key (PKpub). I assumed that was something that had to be loaded from a file from the PC builder so I never tried installing it. Turns out it doesn't require anything; I just had to change "Install Intel Platform Key" to Enabled, save the BIOS & reboot, and now PKpub says "Installed". Once this is done SecureBoot shows it's turned On in Windows 10.
I'm betting the DQ67EP is probably the same way. I don't have access to the one we have right now to test it.
