Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
DQ67SW BIOS update fails
JDobb
I don't know if anyone can help because I think I ended up with a board I shouldn't have.
I have a DQ67SW which is showing to have a 0019 BIOS and it also displays "Evaluation Only" on the BIOS splash screen. I have tried flashing the BIOS through the flash util by hitting F7 on startup and selected the BIOS file located on a USB drive. This Fails with displaying "Flash update Failed!" for the process on firmware update but also displays a "Technical information: (0x800000000000012, 1758)"
The same thing happens when I try iflash and the windows flash software. Just to note, I first tried using the lastest BIOS being 0067 and then tried 0032 just because I thought it might be best trying the oldest one listed for testing.
The reason I want to update the BIOS is so I can use a new CPU I just got being a Pentium G2030 which will not post when installed.
Allan_J_Intel1
I understand you would like to update the latest BIOS on this motherboard.
In order to better assist you, I would need to know the exact model of the motherboard you have. To determine this, please reply with your motherboard's PBA/AA code number and serial number; this is found on a white sticker, usually with a bar code on it.
http://www.intel.com/support/motherboards/desktop/sb/CS-009008.htm http://www.intel.com/support/motherboards/desktop/sb/CS-009008.htm
Allan.
JDobb
Doesn't matter now. I used the live chat and now I have a bricked motherboard and to top it off, it does not show up when running the search for PBA/AA.
Allan_J_Intel1
Thanks for the information.
Allan.
