Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
DQ67SW, PCI Serial Port error. What AMT do I need?
Godbrain
This is the VEN/DEV under hardware ID's.
PCI\VEN_8086&DEV_1C3D&SUBSYS_20088086&REV_04
PCI\VEN_8086&DEV_1C3D&CC_070002
I tried to use the Intel Driver and Support Assistant but unfortunately it didn't detect me missing anything.
n_scott_pearson
Super User Retired Employee
First of all, IDSA is not intended for use on discontinued boards.
You can resolve this device entry by updating the Intel Chipset Device Software package and installing the Intel Management Engine driver package. The versions for your board can be downloaded from here: https://downloadcenter.intel.com/download/22153/Intel-Chipset-Device-Software-for-6-Series-Chipset-B... and here: https://downloadcenter.intel.com/download/20584/Intel-Management-Engine-Driver-5M-for-Intel-Desktop-....
Now, you will notice that these packages do not support installation on Windows 10. That is because Windows 10 is not supported on this board. If you are running Windows 10 and having these problems, then I am sorry but you are stuck with them.
Hope this helps,
