Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
DQ67SW will not power on
oisab
I have a DQ67SW and i7-2600 with no cards installed and 64GB of memory. When I turn on the power switch on the supply he standby-power LED
turns green but if I press the power switch it will not turn on .
I test with two diferents power suply
* CPU power connector http://dl.dropbox.com/u/28596870/2012-02-04%2015.24.55.jpg check
* Motherboard power connector http://dl.dropbox.com/u/28596870/2012-02-04%2015.25.12.jpg check
* Boot with single stick of RAM/RAM fully inserted http://dl.dropbox.com/u/28596870/2012-02-04%2015.25.12.jpg check
* CPU installed correctly? (I assume it is, it was working properly before without any tampering)
* CPU fan plugged in http://dl.dropbox.com/u/28596870/2012-02-04%2015.27.08.jpg check
* System speaker connected http://dl.dropbox.com/u/28596870/2012-02-04%2015.26.38.jpg check
Please Help Me
n_scott_pearson
Super User Retired Employee
64GB? Are you sure? That would be 4 DIMMs, each 16GB in size. Memory totals greater than 32GB and DIMMs larger than 8GB in size are *not* supported by this board. If you really have this size DIMMs, this will explain why you are seeing an issue...
Presuming that that was a typo, please explain how you got to this point. Is this a new build? If not, what happened (be verbose in your explanation; explain what happened, what did you attempt to do about it, etc.)
oisab
32 gb sorry by the mistake .
i solved the problem ,
Connect the power supply to the motherboard and made a bridge by attaching the green wire to the black wire. Then connect the source to the electric current and the computer turned on, generated a bios error but came back to life. Then remove the bridge I made and the computer now works correctly. I think the bios suffered a short or something like that
n_scott_pearson
Hhmmm, could this be one of those situations where the power supply requires a certain load before it will power on and the motherboard (with processor, etc.) is (still) not meeting this loading requirement?
