Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DQ67SW will not power on
I have a DQ67SW and i7-2600 with no cards installed and 8GB of memory. When I turn on the power switch on the supply he standby-power LED
turns green but if I press the power switch it will not turn on (no activity or front-panel LED).
This happened a week ago, I left it unplugged and when I came back after a week hit the power switch and the system came up and booted into linux as usual.
I halted the system, turned off the power supply switch and now its back to the same problem described at the beginning.
Is this a power supply problem or a problem with the PS_ON# circuit on the motherboard?
Power supply is a 300w ATX v2.0
Community Manager
Here are our recommendations for this issue:
-Test the system out of the chassis on a minimal configuration, minimum memory installed and check if the issue persists.
-Test with a different power supply with at least 400-500 watts.
