Intel® Desktop Boards
Peer-to-peer support only
DQ77KB 3D model
Community Manager
Hi Intel guys,
I work for small company, which develops forensic and data recovery equipment
on the basis of Intel motherboards. Previously we successfully used
D945GCLF, D510MO, D525MW, DQ67EP boards in our products.
And our recent project is considered to be built around DQ77KB motherboard.
Please advise, how can I have 3D model of the DQ77KB board to aid device case design?
Any wide-known format would be acceptable, for instance STEP, IGES, SAT, STL.
I saw the model in Technical Product Specification PDF, but unfortunately
fellow engineer could not export it from there.
Thank you.
Andrew
Community Manager
Hello Andrew,
The model designs are not publicly available and there are some steps that need to be covered before having access to them.
Currently I recommend you to contact the customer support to have them guide you where to get such information.
http://www.intel.com/p/en_US/support/contact/phone?redirector_count=1& http://www.intel.com/p/en_US/support/contact/phone?redirector_count=1&
Regards.
Community Manager
Hello Andrew,
Regards.
Community Manager
OK, thank you for the hint.
