Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
DQ77KB PCH ( chipset ) heatsink ( cooler ) holes distance
Community Manager
I have a DQ77KB motherboard.
How big the distance of the holes in the heatsink ( cooler ) of the chipset ( PCH ) is in mm?
In the technical product spezification I could find no information, because in the Board 3D view, the holes do not exist.
And in the 7 series chipset pch thermal design guide, no information as there are, the cooler is fixed with a clamp.
Thanks for any information.
Best regards from Germany
Tom
RRamo7
New Contributor III
Hi
Unfortunately we don't handle Thermal diode measures, located on the Intel Q77 PCH, if it is not in the technical product specification it is not available.
RRamo7
New Contributor III
Hi
