Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
DQ77KB as a headless server question?
Community Manager
Anybody know if the DQ77KB board boots ok if you don't have a keyboard, mouse or Monitor attached?
Also a comment on NewEgg for the DQ77KB said you can't disable Intel AMT , is this a problem at all?
Community Manager
Anyone?
ZAgha
New Contributor II
Yes sure you can boot as a headless server. You just have to disable the halt if no keyboard is present in the BIOS & few tweaks. Thats it
Bear in mind that there are much better boards to build a server within the same price range or a little higher.
Community Manager
Thanks Ziad but it's only for a home file server download box so i don't need a power house.
I know that normally on most boards you just need to do a bios tweak but i need someone with this board to make sure you can as there are a lot of complaints about this board and someone in the intel vt-d section seems to think you need to have a monitor attached with this board before it will boot.
