Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
DQ77KB doesn't start (doesn't turn on)
ПНеха
Hello. I have 2 DQ77KB boards. All of them worked fine but suddanly one of them stoped to turn on.
I had try components (CPU,RAM, Power Supply) from this motherboard on second MB for exclude the probability of malfunction of them. All components work fine.
When I connect power supply and RJ-45 cable to workable MB i have seen 2 LEDs - 1 led on MB (green) and 1 LED on RJ-45 port (green), than I pressed "start" button on the Case and coller begins to rotate.
When I connect power supply and RJ-45 cable to not workable MB i have seen 1 LEDs - 1 led on MB (green) and all. When I pressed "start" button on the Case coller doesn't rotate.
The version of BIOS probably is 0056.
What is the cause of the problem and what to do?
ПНеха
Any ideas?
n_scott_pearson
Super User Retired Employee
Sounds like something has failed on the motherboard. If you are still within your warranty period, contact Intel Customer Support regarding a replacement.
Anonymous
Not applicable
Hi Павл Нехай,
Please perform a test with minimum configuration, I mean using motherboard, processor, 1 memory stick and power supply. Remove the remaining hardware. Check if it possible to get into the BIOS.
If problem continues, contact our support center using the link below.
http://www.intel.com/p/en_US/support/contactsupport Contact Support
ПНеха
Hello. I have tried with minimum configuration - no effect.
Anonymous
Not applicable
Hi Павл Нехай,
Please get in contact with the support warranty using the link below.
Miguel C
