Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
DQ77KB : graphic driver
Community Manager
sorry in advance for my poor english...
I just bought the DQ77KB, installed W7 x32 without any issue along with chipset, audio, lan and usb drivers. But after several tries i'm unable to install the graphic driver (GFX_Win7_8_32_9.17.10.2932)
After reboot, i get a dark screen.
Any advice to make this motherbord work properly ?
Already update bios to last version (0049). Using an i3 3225, microssd Crucial m4, 8gb so dimm and Akasa Euler case.
Thanks in advance.
Community Manager
Hello Olivier, this could be related to the monitor EDID (Extended display identification data) not being recognized and sending an incompatible resolution to your monitor.
I recommend you to test with a different monitor or before you restart the computer to install the monitor driver that should be provided by the manufacturer.
Regards.
Community Manager
Regards.
