Hi, I bought mb DQ77KB with CPU 3220T. When I connect via browser to the management of the board I can't see BIOS settings. Where are they?
Thanks, David
Hello Dave.ce, thanks for contacting us through the Intel Communities.
Regarding to your question I would like to inform you that when you connect via browse, this option will allow you to restart the system or to turn it on and off.
If you want to access to the BIOS, you would need to use another software like VNC viewer or Intel System Defense utility.
Please check the following URL https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21855&ProdId=3444&lang=eng&OSVersion... https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21855&ProdId=3444&lang=eng&OSVersion...
