Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DQ77KB with spdif
Jump to solution
hi,
dq77kb,whether to support spdif out?
where can I find it?
if not support,what can I do?
Community Manager
We would like to inform you that the dq77kb does not have an S/PDIF header or connector built-in reason why we recommend using the audio connectors located on the back panel for the board.
Community Manager
Community Manager
Regret to inform you that Dan_Intel is misinformed. This is not his fault; the Technical Specifications document (3rd revision) does not have complete information on the audio capabilities of this board.
In fact, the DQ77KB does support S/PDIF audio output. The green speaker jack on the back of the board is a dual-function jack. In addition to serving as a 1/8-inch stereo analog audio jack, it is ALSO a Mini-TOSLINK plug.
You can see this for yourself by installing the latest Realtek Audio driver from Intel's website, selecting "Realtek Digital Audio" as your default playback device, and observing the red glow coming from this jack.
You will need a Mini-TOSLINK to normal TOSLINK adapter plug (these cost only a few dollars at Amazon or Fry's), or an optical audio cable that has a mini plug on one end and a normal plug on the other. Of course, you will also need an audio or home theater receiver that supports optical inputs.
I have verified that the S/PDIF output on the DQ77KB can produce 2-channel PCM and 5-channel Dolby Digital and DTS at 44.1, 48, and 96 kHz, with either 16- or 24-bit resolution. My Denon receiver does not support 192 kHz samples, so I haven't verified that.
As you probably know, S/PDIF does not support the newer Blu-Ray audio formats like Dolby HD, nor does it support more than 2 channels of PCM. This is a limitation of S/PDIF itself, not the board.
Community Manager
thank you! I will try it.
MMISS55
