Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
DQ77MK ATA password length and usability?
MBori1
Hello
I need to set an ATA passwords for two SSDs (Samsung 840 evo) connected to SATA0 and SATA1 in AHCI mode on DQ77MK Motherboard. Is that possible with the latest BIOS version?
PS
What is the maximal length of the ATA password?
Silvia_L_Intel1
LordingMike, I understood that you want to set an ATA password for 2 SSDs, however hard driver password is limited to only one drive. That is the reason why this feature is not available when you choose RAID SATA mode.
The hard drive has to be connected to the SATA 0 port. This will enable the 'HDD Password' options on the BIOS.
In regards to the maximal length I would like to tell you that the password needs to be at least 2 characters and at most 8 characters long.
