Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
DQ77MK - BIOS has detected unsuccessful POST attempt(s)
UUbiC
We are experiencing some problems with the DQ77MK motherboard. Randomly, on boot we get this message :
BIOS has detected unsuccessful post attempt(s).
Possible causes include recent changes to BIOS
Performance Options or recent hardware change.
Press 'Y' to enter Setup or 'N' to cancel and attempt to boot with the previous settings.
After searching many hours on this forum and others, I find nothing to fix this problem.
When I press on 'N', the system boots with no problems.
So my question is: Is there any options to disable this message (or to bypass it after some time).
This message is really annoying because the systems we use in our company have no keyboard connected, they just got a touchscreen.
This message appear on many DQ77MK (at least 5 of them) and we always shutdown the systems cleanly.
We use Ubuntu 10.04 LTS 2.6.32-37.
We tried to remove all devices connected on USB3 ports, to change some BIOS options (like "unattended BIOS configuration") and to update the BIOS (we still have the problem with the latest version: 0062).
Stéphane
PSpal
Found a solution -
My PC was not even booting into windows, kept shutting down as soon as i pressed N to the bios message and Y would take me into BIOS Setup.
it was working absolutely fine before going to V0064
Go into Bios
Restore all to Default
And click Performance / Summary
then untick Failsafe Watchdog
then reboot.
must be major bug in the bios v0064
i would try and restore to V0059 im pretty sure this all started after the Visual Bios.
Silvia_L_Intel1
This kind of behavior could be cause by a device such as memory or a network card that is not letting the system to finish posting correctly or it is not being properly detected by the operating system.
How long ago did you start getting this error?
Could you please provide me the system configuration?
Processor:
Memory model number:
Video card:
Any PCI devices:
Hard drives:
UUbiC
I just talk with my colleagues and it seems the message appears since the 0060 BIOS version (August). I did not remember having it with the 0059 version.
We always update the BIOS on new systems to avoid problems with some CPU like we had before.
Here is the hardware configuration of two systems with the problem:
System 1:
PSU: Corsair CX500M
CPU: Core i5 3570K
PCIE:
16x: MSI N450GTS-MD2GD3
4x: Datapath Vision RGB E2S
RAM: Corsair 2x2GB CMX4GX3M2A1600C9
HDD: Seagate 2TB SV35
System 2:
PSU: Corsair CX500M
CPU: Core i5 3570K
PCIE:
16x: MSI N640-2GD3
4x: Datapath Vision RGB E1S
RAM: Crucial 2x2 GB BLS4G3D1609DS1S00
Stéphane
Silvia_L_Intel1
Stephane, thanks for the information.
When installing new BIOS, there are some settings that are being updated also, therefore there could be compatibility issues with legacy hardware.
You may want to try the following:
  • Remove the PCI cards ( MSI video card and VisionRGB-E2S Capture Card), restart the system and check if you are getting the error.
  • In order to find out which device is causing the error, please include one of them and restart the system.
  • You would need to perform the same steps on each card.
  • Finally, you can roll back to the previous BIOS version 0059 through a BIOS recovery. http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS update
UUbiC
Thanks for your answer.
I will try this the next time the message appears.
I guess there is no options to hide this message or to display it only during some time. Am I wrong ?
Stéphane
PPro
Hey Stéphane,
did you manage to solve the Problem?
I get the same random error messages during boot, but on a DH77KC mainboard (no PCI or other extension cards, only graphics card).
My system config:
processor model: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
Memory: 16GB-Kit Corsair Vengeance blue DDR3 1600 MHz CL9
Power supply: be quiet! STRAIGHT POWER CM BQT E9-CM-480W 80+Gold
GPU: Sapphire Vapor-X Radeon HD 7770 OC, 1GB GDDR5
HDD: Crucial RealSSD C300
Monitor: Dell U2410
Silvia_L_Intel1
Hello Pro, please let me know if you performed the troubleshooting provided to Stephane?
Which is the current BIOS version on your motherboard?
Could you test the motherboard using the onboard graphics instead of the video card?
PSpal
Found a solution -
Go into Bios
then reboot.
PPro
Disabling Failsafe Watchdog did solve the Problem on my DH77KC to, independent of the BIOS version (i already tried different versions).
Thanks!
