DQ77MK with 0053 BIOS (latest as of 13 Nov '12), AHCI mode.
We have a need to use two drives with ATA passwords in some machines.
The ATA password only appears to apply to the first SATA port. It does not seem to set one for the second port. If you try to be tricky and set passwords for two drives using SATA0 in turn, and then plug the second drive into SATA1 (second SATA), the board does not seem to unlock the second drive, just the first.
Am I missing a process, or does the BIOS only support ATA passwords on the first SATA port? If so, I would like to ask INTEL to consider adding ATA password support for two drives.
Regards, jp
Usually the password is for the Boot drive only. If you want to secure the 2nd drive then you have to use something like Bitlocker or any third party app.
As for contacting Intel's CS, trust me its easier to talk to the President. Their support has hit rock bottom
