Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
DQ77MK PCIE BIOS BUG
shonk
So i have two machines with Intel DQ77MK Boards
And have found two bios bugs
On S3 Suspend to ram (UEFI OS) the PCH PCIE ports on wakeup only initialize at PCIE 1.0 x 4 Speed
and are stuck that way a straight reboot fixes this so the bios manages to initialize fine on boot
and just has issues on wakeup
I350-T2=Locked at PCIE 1.0 x 4 after S3 UEFI
Toshiba XG3=Locked at PCIE 1.0 x 4 after S3 UEFI
PCIE 3.0 x 16 Slot doesnt have this problem
PCIE 2.0 x 1 Slots i have no idea as my Intel AC-7260's are 1.1
Windows Event Log moans about a HAL problem after S3 in UEFI Mode
and points at a faulty bios if the OS isnt in UEFI Mode this doesnt happen after S3 in the eventlog
No idea if the PCH PCIE 1.0 x 4 Bug happens in non UEFI OS as i only noticed this bug the other day
but noticed the Event Log UEFI Mode S3 Problem quite some time ago
this isnt just a case of PCIE power management before anyone mentions it
but the device is locked at PCIE 1.0 after S3 as can be confirmed by NVME SSD benchmarks of
700 MB/S instead of 1400 MB/S after S3
I have 100% confirmed this is a bios bug im not looking for help on my specific devices
BUT Requesting a Firmware Update that fixes this Problem
Machine 1
Board=Intel Desktop Board DQ77MK
CPU=Intel Xeon E3 1240 V2
Ram=32GB 1600 Mhz
PCIE 3.0 16x Slot=MSI R9 280 3GB OC
PCIE 2.0 4x Slot=Intel I350-T2 (PCIE 2.0 x 4 Card)
PCIE 2.0 1x Mini Slot=Intel AC-7260 (PCIE 1.0 x 1 Card)
OS = Windows 10 Fall Creators Update Uefi Mode
Boot Drive =KINGSTON SV300S37A240G 240GB SSD
PSU=Corsair HX750
Machine 2
CPU=Intel i7 3770
Ram=32GB 1600 Mhz
PCIE 3.0 16x Slot=Sapphire R9 290 4GB Tri-X OC
PCIE 2.0 4x Slot=Toshiba THNSN5256GPU7 XG3 256GB M.2 2280 NVMe (PCIE 3.0 x 4 Card) (non bootable)
Boot Drive=Crucial M550 512GB SSD
PSU=Corsair HX750
Maximum Link Width: 4xCurrent Link Width: 4xMaximum Link Speed: 8.0 GT/sCurrent Link Speed: 2.5 GT/sDevice/Port Type: PCI Express Endpoint
Maximum Link Width: 4xCurrent Link Width: 4xMaximum Link Speed: 5.0 GT/sCurrent Link Speed: 2.5 GT/sDevice/Port Type: PCI Express Endpoint
Shonk1
I have just fitted an Intel I350 T2 in the PCIe 2.0 1x Slot that also does it after standby
So to reiterate
PCIe3.0 16x = Fine
PCIe 2.0 4x = Bug
PCIe 2.0 1x = Bug
mPCIe 2.0 1x = Fine (with an Intel AC 9260 atleast)
Fix.bat
@ECHO OFF SET V=1.0 TITLE DQ77MK STR PCIE 2.5GT/s Fix v%V% cd \Program Files\pciutils @ECHO ON setpci -s 0:1c.4 CAP_EXP+0x30.w setpci -s 0:1c.4 CAP_EXP+0x30.w=0x0002:0x000f setpci -s 0:1c.4 CAP_EXP+0x10.w=0x0020:0x0020 setpci -s 0:1c.4 CAP_EXP+0x30.w setpci -s 0:1c.0 CAP_EXP+0x30.w setpci -s 0:1c.0 CAP_EXP+0x30.w=0x0002:0x000f setpci -s 0:1c.0 CAP_EXP+0x10.w=0x0020:0x0020 setpci -s 0:1c.0 CAP_EXP+0x30.w
Addresses are system-dependent. list devices by typing lspci in an admin command prompt
in my case i want to fix the
4x slot which is 0:1c.0 (PCI Express Root Port 1)
1x slot which is 0:1c.4 (PCI Express Root Port 5)
shonk
This was posted in the support forums a few times when support was still active for desktop boards
Intel support came back that it couldnt be reproduced so it must be an error at the users end
but the reality was consumers where using the board in uefi mode
and support where using legacy mode and nobody put two and two together
In the past i would have fixed the bios myself but intel sign the bios
and as such this can only be fixed by intel
large bugs are still being fixed by intel for desktop boards
e.g. ME bug was patched a few months ago
I request a fix for broken UEFI mode as this has been broken since day1 of release
Log Name: SystemSource: Microsoft-Windows-HALDate: 24/02/2190 20:50:32Event ID: 12
Task Category: None
Level: ErrorKeywords: (1)User: N/AComputer: DQ77MK2
Description:
The platform firmware has corrupted memory across the previous system power transition. Please check for updated firmware for your system.
Event Xml:
http://schemas.microsoft.com/win/2004/08/events/event http://schemas.microsoft.com/win/2004/08/events/event">
1202000x80000000000000015047SystemDQ77MK2
1159159
n_scott_pearson
Super User Retired Employee
Intel exited from the Desktop Boards business a number of years ago. All Desktop Boards are subsequently long past their End-Of-Life dates and long past their End-Of-Interactive-Support dates as well. The sustaining team was disbanded quite some time ago. There is simply no one left to work on any bugs. Yes, it is totally true that Intel delivered updates last year that delivered fixes for a set of security flaws in the Management Engine (ME) firmware, but what you need to understand is that the ME firmware team is part of the Chipset organization and thus active sustaining for this portion of the firmware is (still) ongoing. This is not the case here. There is no one to work on any BIOS bugs. Putting together a team at this point to deliver a fix for this issue would cost many thousands of dollars. It simply isn't going to happen.
Sorry (and remember that I am just the messenger),
shonk
Im sure you know alot more about the teams than me
but they clearly still have bios engineers on site as the nuc's also suffered with this problem
which they promptly replaced a bios module and fixed it
being such a large bug that has been present since release
the least they could do is get one of the nuc team to package up a fix
they clearly know what fixes it as they fixed the nuc bios's
i could fix this myself if i had the capability to sign the firmware
in what 10 mins
Its a simple case of saying fred fix that uefi bug that the nuc's had
on the dq77mk firmware ok jim will have it fixed in 10 mins
n_scott_pearson
No, it is not that simple. First of all, these BIOS were developed on completely different code bases, which means that a fix would need to be independently developed. As I said, doing so and then going through the required regression, validation and release cycles (nothing leaves Intel without it) would take a team of engineers and cost many thousands of dollars. I am sorry, but this is the reality of the situation; it simply isn't going to happen.
shonk
This is the problem with signed firmware nobody can fix it apart from the oem
My only hope tbh is if it doesnt happen in legacy mode
I know the os doesnt moan after coming out of standby in legacy
as mine only started doing it after a fresh install in uefi mode
will wipe one of them in the next few days and check
the event log didnt bother me i just stopped windows logging it
but didnt realise until yesterday that the 4x slot was being downgraded after standby
shonk
I did a fresh legacy install
it fixed the event log error after standby
but the 4x slot still gets dropped down to gen 1 after standby
so its two different bug's
n_scott_pearson
Thanks for the into. Unfortunately, at this point, all we can do is document the issues in case someone else runs into it.
shonk
Im looking into forcing a link speed now in the registry with RMPcieLinkSpeed
i just need to find the area for the i350-t2 and the nvme ssd
Here's the reg fix to stop windows moaning about s3
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\WMI\Autologger\EventLog-System\{63d1e632-95cc-4443-9312-af927761d52a}]
"Enabled"=dword:00000000
Shonk1
I know this is an old post
but i have recently worked out how to manually fix this after every Suspend to Ram
and think its good to document incase anyone else wants to fix this
as i have recently put an nvme drive in this slot i spent a good while looking up how to fix this
as i didnt want the nvme drive degraded down to gen1 4x after the first sleep as this pc is on 24/7
DQ77MK isnt usually bootable via nvme due to a lack of nvme option rom
but i inject the nvme module into the uefi on every boot with rEFInd Boot Manager
i wont go into how thats done here but suffice to say its doable if you know what you are doing
I have created a scheduled task that is triggerd on Event ID 107 (e.g. The system has resumed from sleep.)
to run a batch file (C:\Program Files\pciutils\Fix.bat)
for this you need a copy of pciutils that has been built for windows (its a linux utility)
I used pciutils-3.5.5-win64 (has to be run with administrator priv's ofc)
the batch file consists of below you can test it works by manually running it as administrator then checking link speed with hwinfo64
The first line with setpci shows the current max link rate which will be Gen1 (so this doesnt have to be used its just for info)
The second line with setpci sets the max link rate to Gen2
The third line with setpci triggers a retrain of PCI Express Root Port 1
The forth line with setpci shows the current max link rate which will be Gen2 (so this doesnt have to be used its just for info)
Fix.bat
@ECHO OFF SET V=1.0 TITLE DQ77MK STR PCIE 2.5GT/s Fix v%V% cd \Program Files\pciutils @ECHO ON setpci -s 0:1c.0 CAP_EXP+0x30.w setpci -s 0:1c.0 CAP_EXP+0x30.w=0x0002:0x000f setpci -s 0:1c.0 CAP_EXP+0x10.w=0x0020:0x0020 setpci -s 0:1c.0 CAP_EXP+0x30.w
in my case i want to fix the 4x slot which is 0:1c.1 (PCI Express Root Port 1)
the mini pcie slot doesnt exhibit this problem as my Intel AC 9260 runs just fine in Gen2 after STR)
the 16x slot is also fine it sits on gen1 at idle then goes to gen3 when the gpu is loaded
Shonk1
I suspect there may be a much cleaner fix via the registry with a flag forcing gen2
e.g. on my device
Intel Panther Point PCH - PCI Express Port 1 HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_8086&DEV_1E10&SUBSYS_20358086&REV_C4   Toshiba AIS NVMe SSD Controller HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_1179&DEV_010F&SUBSYS_00011179&REV_01
but after alot of looking up said flags i couldnt find info on it so will have to make do with the fix above
Shonk1
So to reiterate
PCIe3.0 16x = Fine
PCIe 2.0 4x = Bug
PCIe 2.0 1x = Bug
Fix.bat
