Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
DQ77MK motherboard using onboard graphics with intel HD Graphics Driver boots to Black Screen
Community Manager
DQ77MK motherboard using onboard graphics with intel HD Graphics Driver boots up to Black Screen on startup. Driver version 9.17.10.2932. Never displays unless I delete the driver and use standard VGA driver. When in Black screen mode, I can remote connect from another desktop and see desktop fine. All updates and service packs for Windows 7 Ultimate OS installed. BIOS ver. MKQ7710H.86A.0039.2013.0111.1351
Community Manager
Here are our recommendations for this issue:
- Check for driver conflicts in device manager. Make sure you have followed a clean installation of the Operating System.
- Update your motherboard BIOS gradually to versions: 0050, 0054 0057. We recommend using the recovery method since is the most secure one.
BIOS versions can be found here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=... http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=...
Please be sure to read and follow all accompanying instructions, which can be found at this link:
http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm Desktop Boards — BIOS update instructions
Community Manager
