Intel® Desktop Boards
Peer-to-peer support only
11476 Discussions
DQ87PG 142 Bios killed graphics
mman2
Hi there,
the new BIOS (ver. 142) for the DQ87PG fixed most of the issues introduced by ver. 139/141. Thanks a lot.
One annoying issue remains, though. The onboard Display Port output does not work any more. The DVI output works just fine, though.
I use a generic Displayport 2 HDMI adapter, and a HDMI cable, on a regular monitor. This very setup used to work just fine pre ver. 141.
Any pointers for me?
Thanks!
Merrill
EDIT: The display port adapter is probably this one: http://www.amazon.com/Cable-Matters-Plated-DisplayPort-Adapter/dp/B005H3I38Q Amazon.com: Cable Matters Gold Plated DisplayPort to HDMI Male to Female Cable Adapter: Electronics
Silvia_L_Intel1
Merrill, I'm going to set all this up, in order to duplicate your issue. I'll keep you posted
Silvia_L_Intel1
Merrill, we were not able to reproduce this issue in our laps.
Do you have any update? Were you able to fix it?
Please let me know
