Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
DQ87PG 142 Bios killed graphics
mman2
Hi there,
the new BIOS (ver. 142) for the DQ87PG fixed most of the issues introduced by ver. 139/141. Thanks a lot.
One annoying issue remains, though. The onboard Display Port output does not work any more. The DVI output works just fine, though.
I use a generic Displayport 2 HDMI adapter, and a HDMI cable, on a regular monitor. This very setup used to work just fine pre ver. 141.
Any pointers for me?
Thanks!
Merrill
EDIT: The display port adapter is probably this one: http://www.amazon.com/Cable-Matters-Plated-DisplayPort-Adapter/dp/B005H3I38Q Amazon.com: Cable Matters Gold Plated DisplayPort to HDMI Male to Female Cable Adapter: Electronics
Silvia_L_Intel1
Merrill, I'm going to set all this up, in order to duplicate your issue. I'll keep you posted
Silvia_L_Intel1
Merrill, we were not able to reproduce this issue in our laps.
Do you have any update? Were you able to fix it?
Please let me know
