I'm using BIOS version 148 and a Core i3-4340 @ 3.60 GHz which (according to the board's compatible processor list) is compatible with this board.
The BIOS shows me a "Host Clock Frequency" of 100 MHz and 2.70 GHz - indicating that the CPU is running at a maximum speed of 2.70 GHz instead of 3.60 GHz. And indeed, the processor cores' maximum non-turbo ratio is fixed at 27 which I cannot change! Moreover, CPU speed and frequency tools show that the maximum speed step of my CPU is in fact merely 2.70 GHz instead of 3.60 GHz!
So, what do I have to do to get the maximum CPU speed of 3.60 GHZ I've payed for?
Additional information: The BIOS option to enable turbo boost is available although the i3 doesn't have turbo boost. I can check it, but after re-entering the BIOS, it's unchecked again.
So, it seems that there is a BIOS bug, detecting the i3-4340 as boostable (although it isn't) and thus limiting the non-boost speed (which is the normal speed) to 2.7 GHz.
Intel, please check, respond and fix!
Hello Jb0, thanks a lot for posting your inquire at Intel communities.
Please note that Intel® Turbo boost is engaged automatically depending on processor load, voltage, power and temperature. However, your processor does not comes with this technology therefore you should be able to change the multiplier manually (36x).
These are the recommendation I could give you:
Regards.
sylvia_intel, thanks for your reply.
I know that my i3-4340 doesn't come with turbo boost technology. Nevertheless, the BIOS gives me an option to enable/disable "Intel® Turbo Boost Technology" (always unset when entering the BIOS again) and, on the other hand, the multiplier is read only (shown greyed out) and fixed to 27 (please see my posting above).
I'd love to be able to change the multiplier manually to 36!
As I've mentioned, I'm using BIOS version 148 which seems to be the most recent one.
It very likely seems that there is a BIOS bug detecting the i3-4340 as boostable (although it isn't). BTW, the CPU's microcode (Microcode Update Revision) is 00000017, if that helps. Unfortunately, I cannot test the processor on another computer.
If you need additional information, please ask.
This issue seems to be cause by a defective motherboard or processor, but since we are not able to test the chip on another system what I can suggest you is to get in touch with our technical team http://www.intel.com/p/en_US/support/contactsupport Contact Support or submit a web ticket to request an RMA. Remember that the processor or the motherboard needs to be under warranty.
https://servicerequestmgmt.intel.com/webticketui/emailpage.aspx?lang=en-us https://servicerequestmgmt.intel.com/webticketui/emailpage.aspx?lang=en-us
sylvia_intel,
will do, although I'm not happy to probably disassemble the just being assembled CPU and board.
Are you really sure that it couldn't be just a BIOS flaw which is somehow misinterpreting the data of the (relatively new) CPU? I'd be glad if there were a possibility to somehow check this by software (on a USB stick) without an already installed OS - and I'm not using Windows anyway.
What I don't understand and what IMO points to a BIOS flaw: Since the BIOS correctly detects the CPU as Core i3-4340 @ 3.60 GHz, shouldn't it be able to handle the multiplier option correctly as well then? AFAIK, there is only one i3-4340 @ 3.60 GHz, so the necessary BIOS options for the various settings should be unambiguous and the limitation of the multiplier to 27 doesn't make any sense.
Jbo, I do understand your point, so if you want you could try to install the BIOS version again using the recovery method. http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS update
The only way to update the microcode of the processor is through a BIOS update.
Then, if the issue persisted please get in touch with our warranty team.
sylvia_intel,
I did install the BIOS again using the recovery method, but - as expected - nothing changed.
But when thinking about why you recommended that, I suspected that loading the BIOS defaults might not be a bad idea and ... Ta-dah! ... the multiplier miraculously has changed to 36, giving me the maximum CPU speed of 3.60 GHz now.
So, I'm finally having my CPU running at full speed, but still I'm thinking that there are BIOS bugs. You might want to pass them to the BIOS programmers for fixing them in the next version:
I'm glad to know that you were able to find the solution for this issue.
In additiion, thanks a lot for all the feedback given. I already send it to the corresponding team.
