Community
cancel
Showing results for
Search instead for
Did you mean:
rCame2
DQ87PG setting up raid
Jump to solution
How do I setup raid to work on this motherboard? I've gone into bios and enabled raid and RST, but I'm not seeing any raid menus like I would on the older MBs. What am I missing?
n_scott_pearson
Super User Retired Employee
You changed the SATA Mode to RAID, saved the configuration and exited Visual BIOS and then did CTRL-I during the subsequent BIOS POST?
n_scott_pearson
rCame2
I tried this, but must have waited too late. I tried again and pressed control and I early and it worked. Thanks Scott.
Is there a way to turn off or exit the splash screen?
n_scott_pearson
Yea, I start hitting the key combination, over and over, immediately after powering on or immediately after the screen goes blank when exiting the Visual BIOS Setup program or when restarting Windows/Linux.
No, you cannot disable the splash screen. I believe that you can shorten the amount of time that it will wait for a keystroke to be entered. You can also change the image displayed on this splash screen (using Intel Integrator Toolkit).
