Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
[ DQ965SS ] : BIOS update , Audio Driver problem
hfgh
Hi
I have problem in my motherboard
after format , the Audio driver dosen't work in windows XP
i try this Driver :
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=13706&lang=eng https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=13706&lang=eng
but doesn't work ( Error 10 ) !!
the motherboard model is encrypt or i don't know , but i found the model in motherboard
in dxdiag also in cpu-z
and i try update bios using :
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18158&lang=eng https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18158&lang=eng
i try exe and flash but i can't
i hope found solution here
Silvia_L_Intel1
Hello Uxon, I would like to know if you were able to solve this issue?
Would you please go to the BIOS and let me have the BIOS version installed on your system. It will be the number after the 86A?
